Page 1 of 1
[ 9 posts ] |
Kodicom Xubuntu: xawtv ok; zm not: Aborted (core dumped)
| Author |
Message |
fede
I have been trying for a while to get zoneminder 1.22.3 to work under xubuntu (ubuntu version with xfce default desktop). I've installed zoneminder using Peter Howard's .deb for Debian unstable, 1.22.3-6. The DVR card seems to be detected properly; the camera works fine under xawtv. But running zmu produces the following:
I can't get any monitors running under zoneminder: I never get an image, and the link to the device always displays in red (which I suppose must be because there is a problem with it, since the same happened when I pointed to the nonexistant device /dev/video by mistake). As far as I can tell (not too much, btw  ), the card itself seems to be working, because I can see myself in xawtv; I just can't get it to play with zoneminder. There are some errors in zmdc.log and zmwatch.log, as well. Thanks in advance for any help!!! Federico. zmdc.log:  |  |  |  | Code: 05/02/2007 16:52:26.394585 zmdc[5379].INF [Server shutdown at 07/05/02 16:52:26] 05/02/2007 16:52:27.225049 zmdc[5578].INF [Server starting at 07/05/02 16:52:27] 05/02/2007 16:52:30.820746 zmdc[5578].INF ['zmc -d /dev/video0' starting at 07/05/02 16:52:30, pid = 5600] 05/02/2007 16:52:30.865841 zmdc[5578].ERR ['zmc -d /dev/video0' exited abnormally, exit status 255] 05/02/2007 16:52:30.866629 zmdc[5578].INF [Starting pending process, zmc -d /dev/video0] 05/02/2007 16:52:30.868254 zmdc[5578].INF ['zmc -d /dev/video0' starting at 07/05/02 16:52:30, pid = 5602] 05/02/2007 16:52:30.884738 zmdc[5578].ERR ['zmc -d /dev/video0' exited abnormally, exit status 255] 05/02/2007 16:52:31.089138 zmdc[5578].INF ['zmfilter.pl' starting at 07/05/02 16:52:31, pid = 5603] 05/02/2007 16:52:31.712312 zmdc[5578].INF ['zmaudit.pl -c' starting at 07/05/02 16:52:31, pid = 5605] 05/02/2007 16:52:32.175934 zmdc[5578].INF ['zmwatch.pl' starting at 07/05/02 16:52:32, pid = 5607] 05/02/2007 16:52:35.075623 zmdc[5578].INF [Starting pending process, zmc -d /dev/video0] 05/02/2007 16:52:35.079940 zmdc[5578].INF ['zmc -d /dev/video0' starting at 07/05/02 16:52:35, pid = 5609] 05/02/2007 16:52:35.094179 zmdc[5578].ERR ['zmc -d /dev/video0' exited abnormally, exit status 255] 05/02/2007 16:52:45.095468 zmdc[5578].INF [Starting pending process, zmc -d /dev/video0] 05/02/2007 16:52:45.107865 zmdc[5578].INF ['zmc -d /dev/video0' starting at 07/05/02 16:52:45, pid = 5610] 05/02/2007 16:52:45.114622 zmdc[5578].ERR ['zmc -d /dev/video0' exited abnormally, exit status 255] 05/02/2007 16:53:02.615458 zmdc[5578].INF ['zmc -d /dev/video0' starting at 07/05/02 16:53:02, pid = 5612] 05/02/2007 16:53:02.625875 zmdc[5578].ERR ['zmc -d /dev/video0' exited abnormally, exit status 255] 05/02/2007 16:53:12.859313 zmdc[5578].INF ['zmc -d /dev/video0' starting at 07/05/02 16:53:12, pid = 5614]
zmwatch.log: dmesg | grep bttv:  |  |  |  | Code: [ 25.141420] bttv: driver version 0.9.16 loaded [ 25.141426] bttv: using 16 buffers with 2080k (520 pages) each for capture [ 25.141519] bttv: Bt8xx card found (0). [ 25.141574] bttv0: Bt878 (rev 17) at 0000:02:0c.0, irq: 21, latency: 32, mmio: 0xee6fe000 [ 25.141592] bttv0: using: Kodicom 4400R (slave) [card=133,insmod option] [ 25.141629] bttv0: gpio: en=00000000, out=00000000 in=00ffffff [init] [ 25.142501] bttv0: using tuner=-1 [ 25.142506] bttv0: i2c: checking for TDA9887 @ 0x86... not found [ 25.143321] bttv0: registered device video0 [ 25.143380] bttv0: registered device vbi0 [ 25.143409] bttv0: PLL: 28636363 => 35468950 .. ok [ 25.180888] bttv: Bt8xx card found (1). [ 25.180938] bttv1: Bt878 (rev 17) at 0000:02:0d.0, irq: 20, latency: 32, mmio: 0xee6fc000 [ 25.180953] bttv1: using: Kodicom 4400R (master) [card=132,insmod option] [ 25.180987] bttv1: gpio: en=00000000, out=00000000 in=00ffffff [init] [ 31.573132] bttv1: using tuner=-1 [ 31.573139] bttv1: i2c: checking for TDA9887 @ 0x86... not found [ 37.965473] bttv1: registered device video1 [ 37.965771] bttv1: registered device vbi1 [ 37.965802] bttv1: PLL: 28636363 => 35468950 .. ok [ 38.002588] bttv: Bt8xx card found (2). [ 38.002641] bttv2: Bt878 (rev 17) at 0000:02:0e.0, irq: 19, latency: 32, mmio: 0xee6fa000 [ 38.002660] bttv2: using: Kodicom 4400R (slave) [card=133,insmod option] [ 38.002700] bttv2: gpio: en=00000000, out=00000000 in=00ffffff [init] [ 44.393073] bttv2: using tuner=-1 [ 44.393081] bttv2: i2c: checking for TDA9887 @ 0x86... not found [ 50.785411] bttv2: registered device video2 [ 50.785653] bttv2: registered device vbi2 [ 50.785693] bttv2: PLL: 28636363 => 35468950 .. ok [ 50.820274] bttv: Bt8xx card found (3). [ 50.820328] bttv3: Bt878 (rev 17) at 0000:02:0f.0, irq: 23, latency: 32, mmio: 0xee6f8000 [ 50.820353] bttv3: using: Kodicom 4400R (slave) [card=133,insmod option] [ 50.820392] bttv3: gpio: en=00000000, out=00000000 in=00ffffff [init] [ 57.209037] bttv3: using tuner=-1 [ 57.209045] bttv3: i2c: checking for TDA9887 @ 0x86... not found [ 63.601385] bttv3: registered device video3 [ 63.601650] bttv3: registered device vbi3 [ 63.601689] bttv3: PLL: 28636363 => 35468950 .. ok
lspci: Card detection : modprobe.confI am using a Kodicom 4400R DVR card, so I included the following lines in /etc/modprobe.d/aliases: /etc/modprobe.d/options:
I attach the full logs in tar.gz here: http://www.camaragnc.org/data/zm_logs-fede.tar.gz
Thanks again!
| Thu May 03, 2007 12:23 am |
cordel
Joined: Fri Mar 05, 2004 5:47 pm Posts: 5218 Location: /USA/Washington/Seattle
Something is amiss as this all looks good.
Are you sure ZM is running?
Do you have zm.conf set for the same user/group as apache?
What permisions does zmfix have?
| Thu May 03, 2007 12:29 am |
fede
Thanks for the quick reply!
How can I find out if ZM is running? I can see the web page allright, add a monitor, change options. If I restart it, there appear to be no errors, and I can confirm this in the logs:
I have just supposed that this meant that zm was running - am I wrong? zm.conf belongs to www-data; apache to root. I can't find out anything else about www-data: I can't see this user belonging to any groups in the graphical user management tool (and I don't know how to do it from the command line yet). Is this the problem? zmfix belongs to root.
Thanks a lot!
| Fri May 04, 2007 5:47 pm |
cordel
Run this from the command line:
Then restart ZM.
| Fri May 04, 2007 6:57 pm |
fede
Thanks a lot, Cordel!!!
It is working now. Wonderful!
zmu -d /dev/video0 -q -v doesn't yet work, though: I still see the aborted (core dumped) message. I hope this won't be a problem for anything else; not that I think it's important right now, I only know that zmu -d ... -q -v is supposed to give some info about the hardware or something like that... er...
Thanks again.
| Fri May 04, 2007 7:50 pm |
Jo
I know this is a little old, but I get "aborted (core dumped)" on ubuntu if I try to run that command and forget to "sudo" in front of it.
| Fri Jun 15, 2007 11:22 pm |
don_xvi
+1
I just wanted to echo my experience with Ubunbu 7.04 Feisty Fawn that I needed to duplicate this to get it running. Also, as noted, I needed to use sudo in order to get zmu to run.
| Mon Jul 09, 2007 5:00 am |
whatboy
I replaced the Card with a Kodicom clone, and now the video is coming and going, video, blue screen, video, blue screen, and I touch the card and it is hot, the card came with heat sinks on its bttv chips, but are too damn tiny, I got bigger ones, but the ones in it, are too damn hard to take off...
Why is soo damn hot??? the prev, Techwell 6805 was cool... but driver is jumpy...
| Sat Mar 27, 2010 6:26 am |
mastertheknife
Joined: Wed Dec 16, 2009 5:32 pm Posts: 553 Location: Israel
Seems like your monitors are conflicting, as happened here:
http://www.zoneminder.com/forums/viewto ... dicom+8800
You should try deleting all monitors and re-creating them one by one with lots of care regarding the device and channel.
| Sat Apr 03, 2010 1:59 pm |
Page 1 of 1
[ 9 posts ] |
Who is online |
Users browsing this forum: No registered users and 1 guest |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
