View unanswered posts | View active topics It is currently Mon May 20, 2013 10:17 pm
Reply to topic  [ 8 posts ]
Streaming to an Xbox?
Author Message
Post Streaming to an Xbox?
I have been trying without much success to stream video from ZM to my Xbox(s) to use them as convientiant viewers around the house...
They're all running XBMC (M Player) but I dont think I have the syntax of the playlist entry correct...
I have been creating .stm files (based in what I found in teh XBTV files) which are detected as playlists on XBMC. In there I have been putting an URL to the ZM stream,
http://192.168.1.5/cgi-bin/zms?Zode=jpe ... &maxfps=25
Looks like XBMC prefers .asf files, any way to stream them in ZM (ffmpeg or similar) ?
Anyone else tried this ?
_________________
Regards,
Jason
Sun Jan 01, 2006 8:36 pm
Profile WWW
Site Admin
Post
If you have ffmpeg libraries installed you can stream in asf mode, though the normal Window Media Player viewer does start to lag fairly quickly.
Did you mean 'Zode' by the way? If so then it should be 'mode' obviously. To stream asfs change the mode to 'mpeg' and add a 'format=asf' url parm.
Phil
Sun Jan 01, 2006 9:48 pm
Profile ICQ YIM WWW
Post
Smashing, thanks for that will give it a try tomorrow... yup I think I meant Mode ;) :)
_________________
Regards,
Jason
Mon Jan 02, 2006 1:59 am
Profile WWW
Post
You ever get this working? Streaming to xbmc?
I'd like to try this as well.
Sun Feb 05, 2006 6:43 pm
Profile
Post
Just read this thread:
http://www.zoneminder.com/forums/viewtopic.php?t=3780
If we could get a python script to simply serve this mplayer url then we could get a xbmc plugin for zoneminder.
I know this is possible but I've never written a python script before.
This would also allow a cheap zoneminder client viewer for users.
Sun Feb 05, 2006 7:03 pm
Profile
Post
Can you recommend a good video player to replace Windows media player?
Needs to be free, and as good as Media player. Media Player is not playing all of my downloaded files, I’m running XP and this is for downloaded files, not DVD’s movies.
________________
keyword research ~ keyword tool ~ keyword tracking ~ affiliate elite
Sat Jun 06, 2009 8:37 am
Profile
Post
for me its vlc
plays everything (even real player files as of last release
Videolan.org
_________________
GOOGLE TUTORIAL
Professional ZM install
Give PM or email.
E-lance Profile Link
Experiment/Blog
Sat Jun 06, 2009 8:56 pm
Profile YIM
Post
The days of Xbox... Just install Zoneminder on a 2.6 Kernel Xebian install. I probably still have the precompiled Kernel along with 5 Xbox's in the cabinet that need worked on.
Heck, i've had Ubuntu running on the 360, you talk about the biggest pain to downgrade and get ahold of KK and the SDA disk. Was fun for about a week and then it got piled up with the rest of my projects. This was before I messed with Zoneminder, would have been cool to see it up and running if it would work with powerpc or whatever it is.
Sat Jun 06, 2009 11:16 pm
Profile WWW
Display posts from previous:  Sort by
Users browsing this forum: No registered users and 0 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
