View unanswered posts | View active topics It is currently Wed May 22, 2013 2:42 pm
Reply to topic  [ 92 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 7  Next
Getting ZoneMinder into debian and ubuntu
Author Message
Post
can you provide source debs?
i mean the .dsc + .tar.gz + .changes files.
i would like to test them on my ubuntu system.
Thu Feb 01, 2007 11:46 am
Profile
Post
Those are up on debs development site when it becomes available. I don't think anything is ready yet as it was just put in.
Thu Feb 01, 2007 4:40 pm
Profile WWW
Post
Sorry about the delay on response. You can get them from http://mentors.debian.net/debian/pool/main/z/zoneminder/ or from ftp://www.northern-ridge.com.au/zoneminder
Mon Feb 05, 2007 11:55 pm
Profile YIM WWW
Post Finally!!!!!!!!
For those still watching this topic . . . Zoneminder was finally accepted into Debian unstable this morning.
Phew!
And its the 1.22.3-3 version which installs properly (as opposed to the "don't try to install this unless you like pain" -1 version)
Mon Mar 12, 2007 12:32 am
Profile YIM WWW
Post Re: Finally!!!!!!!!
Phew!
excellent!
Tue Mar 13, 2007 2:53 pm
Profile
Post exciting!
I'm happy you're creating a package. I have installed zm a few times and it's tough work. The howto's for ubuntu skip steps and I spend countless nights searching posts.
I am trying to use the deb on dapper and have a few problems. Are there instructions somewhere?
I removed my zm database and get an error that the package can't connect to it. Should I create that? It seems like I need to go through a few of the installation steps.
I also had issues because I wasn't using the stock username/password. Is it zmpass?.
prepare_cached can't be called on an undefined value at config.pm line 91.
There were other compilation failures but I would like to fix the obvious problems first.
Tue Apr 17, 2007 6:13 pm
Profile
Post Re: exciting!
No formal instructions; it should just install. The only special detail is in the README.debian file (to do with linking the apache config file).
The package attempts to create the database from scratch; I'm not 100% sure what's going wrong here, but if there's not zm database at all in mysql it should create it properly (and yes, the default username & passwd are used in the package)
Sounds like this is just fallout from the above.
Which version of the package are you using? You say "compilation failures" - are you trying to build from the source package?
PJH
Wed Apr 18, 2007 12:59 am
Profile YIM WWW
Post Re: exciting!
I am using 1.22.3-6 that I downloaded from your site yesterday. I am probably making some simple mistake... :)
This is from the terminal window feedback when you install the package via the gui. It talks about compilation failures. The first problem is that DBI connect failed because the database zm is unknown.
Do I need to create a mysql account before running this and/or is there assumption about mysql root access to create the database?
Thanks for the help. I appreciate your taking the time to create a package for this!
Ryan
Wed Apr 18, 2007 4:25 am
Profile
Post
How did you install mysql? The relevant bits from the postinstall script are:
Code:
mysqladmin --defaults-file=/etc/mysql/debian.cnf -f reload
cat /usr/share/zoneminder/zm_create.sql | mysql --defaults-file=/etc/mysql/debian.cnf
echo 'grant select,insert,update,delete on zm.* to 'zmuser'@localhost identified by "{deleted}";' | mysql --defaults-file=/etc/mysql/debian.cnf mysql
So it expects the standard debian.cnf to be there. If you installed mysql via apt-get, it should be there.
Wed Apr 18, 2007 5:02 am
Profile YIM WWW
Post more info
I believe it was there from the original ubuntu installation. I use apt-get or synaptic to install/update.
Code:
I checked and it's there.
Could you explain the passwords to me? First, where you have "deleted" above, are you hiding the password or is this the real code? I have been using "zmpass" for zmuser. I don't understand how an installer can create the databases without root access to mysql...
I ran the above code and it created the database. I still get the same error when I install the package. Access denied for user 'zmuser'@localhost (using password: YES).
Thanks again!
Ryan
Wed Apr 18, 2007 5:43 am
Profile
Post
Are you able to purge the package? i.e.
Code:
sudo dpkg --purge zoneminder
(Don't try reinstalling after that; I need to check up something and I primarily want to see if that works)
Wed Apr 18, 2007 6:11 am
Profile YIM WWW
Post think purge worked
I believe the purge worked but I got similar error messages (shown below). The database was gone. Thanks.
Ryan
ryan@ubuntu:~$ sudo dpkg --purge zoneminder
Password:
(Reading database ... 112357 files and directories currently installed.)
Removing zoneminder ...
Stopping ZoneMinder: DBI connect('database=zm;host=localhost','zmuser',...) failed: Access denied for user 'zmuser'@'localhost' (using password: YES) at /usr/local/share/perl/5.8.7/ZoneMinder/Config.pm line 89
Can't call method "prepare_cached" on an undefined value at /usr/local/share/perl/5.8.7/ZoneMinder/Config.pm line 91.
BEGIN failed--compilation aborted at /usr/local/share/perl/5.8.7/ZoneMinder/Config.pm line 100.
Compilation failed in require at /usr/local/share/perl/5.8.7/ZoneMinder.pm line 33.
BEGIN failed--compilation aborted at /usr/local/share/perl/5.8.7/ZoneMinder.pm line 33.
Compilation failed in require at /usr/bin/zmpkg.pl line 45.
BEGIN failed--compilation aborted at /usr/bin/zmpkg.pl line 45.
Zoneminder already stopped
Database "zm" dropped
Purging configuration files for zoneminder ...
Wed Apr 18, 2007 6:20 am
Profile
Post Clearing out residue
Now go into mysql as root, and change to database mysql.
Look for any mention of zoneminder (e.g. "zmuser") in the table "user" and get rid of it.
Then try the reinstall over; i.e. "sudo dpkg install zoneminder_1.22.3-6_i386.deb" and, if necessary, "sudo apt-get -f install" and see what happens.
Wed Apr 18, 2007 6:44 am
Profile YIM WWW
Post progress
zmuser wasn't in the user table.
The reinstall reported success and didn't give any errors. :) The database and user are in mysql.
I still don't get zm via the browser. /var/www/zm and its html sub are empty.
Ryan
Wed Apr 18, 2007 7:01 am
Profile
Post README.debian
To save you looking right now:
Code:
sudo ln -s /etc/zm/apache.conf /etc/apache2/conf.d/zm.conf
sudo /etc/init.d/apache2/reload
Wed Apr 18, 2007 7:05 am
Profile YIM WWW
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
