View unanswered posts | View active topics It is currently Tue May 21, 2013 7:23 am
Reply to topic  [ 85 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
Cron / Calendar Integration
Author Message
Post
My distro is Ubuntu 6.10 Edgy Eft with PHP Version 5.1.6-1ubuntu2.1, and MySql version 5.0.24a-9 and Apache version 2.0.55-4ubuntu4.
ZM runs in \var\www\zm\ directory, calendar is copy to \var\www\ and calendar config in to \var\www\config\.
The \var\www\html\ directory is empty.
The \var\www\config\ and \var\www\config\lang have 755 permision and the files into this directory have 644 permission.
I've read your ReadMe.txt but i haven't understood this:
4. : Then you need to copy the file dvos.cron to your cron.d directory, on FC4 based systems that will be in /etc/cron.d/
The next thing you need to do is to edit the cron job with Webmin (or your favorite cron job editor) and change the
path to where you put the php scripts in your apache root, you may also need to change the path to the php command.
The one in the job is for FC4.
Thanks.
Ettore
________
XR125L
Sun Nov 26, 2006 2:25 pm
Profile
Post
Hi ziopippo
From what i can see, there might be a problem with where you have installed the frontend / ZM, i would suspect that even on an Ubuntu distro apache is configured to look inside the /var/www/html directory to work proberly, but that you can see in the Apache config file.
The dvos.cron file is located in the tgz file you have downloaded with the frontend, the file is the one that tells cron how often and what the command is for the calendar function to work.
_________________
Best Regards
Tom Stage
Mon Nov 27, 2006 2:28 pm
Profile WWW
Post
I've check the cinfig file, apache is configured to look inside the /var/www directory. I've the same error. :(
How i must see language permissions?
I know how are located the file dvos.cron, but i don't haven understood this:
"The next thing you need to do is to edit the cron job with Webmin (or your favorite cron job editor) and change the
The one in the job is for FC4." ;)
Thanks.
Ettore.
________
CHRYSLER SEBRING (SEDAN) HISTORY
Tue Nov 28, 2006 12:48 am
Profile
Post
Hi ziopippo
Ok so the Apache Config is correct, then it should work, an installation on a FC4 system would look like this.
/var/www/html/
This is where the frontend files will be located, then ZoneMinder is installed in a subdirectory named zm, that will make a structure that looks like this.
/var/www/html/ The Location of the frontend files and directorys.
/var/www/html/zm/ The location of the ZoneMinder Files and directorys.
Normally if the files are owned by the webuser there will be no problems at all, or if the permissions on the whole structure below /var/www/html are 755.
So in your case i would try to change the owner of the files to the webuser on the whole structure below /var/www/.
I hope this will resolve your problem.
_________________
Best Regards
Tom Stage
Wed Nov 29, 2006 6:16 pm
Profile WWW
Post
I think to have resolved some problems. I have only had to cancel the cookie in my browser and change the default language into dvos database (User_Language at the admin table) :wink:
Now i have only problems to show my logs. :? I have already modified the path into config.php file. :wink:
This is my error messages:
Code:
Warning: file(./logs/messages): failed to open stream: No such file or directory in /var/www/config/dvos.inc.php on line 269
some errors occurs: Array ( [0] => your path [./logs] doesn't exists )
________
Sell vaporizers
Thu Nov 30, 2006 4:53 pm
Profile
Post
Hi ziopippo
Hmm is the messages file the only one with the error or is it the only one you have tryed to open ??
_________________
Best Regards
Tom Stage
Fri Dec 01, 2006 6:02 pm
Profile WWW
Post
All the log button give me error message.
This is my config.php file whith my configuration:
Code:
$cron_file = '/etc/cron.d/dvos.cron';// Path to the cron job file in your cron.d directory
// $cron_file = './dvos.cron';// This line is used for programming purpuses only edit the above instead
$cmd_zmpkg = "perl -T /usr/local/bin/zmpkg.pl '"; // Remember to change this to the path for your zmpkg.pl file on your system
$viewlogs = true; // If log viewing is active or not
$systemlogs = true; // This is used to tell if you want to be able to view the messages / access_log / error_log
$webuser = 'apache'; // The user that apache runs under, on Fedora Core the default is apache
$logroot = '/var/log/'; // Path to the main log directory
$zmlogfiles = '/tmp/'; // Path to the ZoneMinder Logfiles
$httpdlogfiles = '/var/log/apache2/'; // Path to the Apache Logfiles
________
Buy Air One Vaporizer
Fri Dec 01, 2006 11:32 pm
Profile
Post
Hi ziopippo
Ok i would suspect that you have a problem with Sudo changes that is discribed in section 7 in the ReadMe.txt file.
The changes are needed to allow the webuser to copy, remove and chown the files in the temporary log file directory, the way this log function works is that we take a copy off the original log file, to make sure that we are not messing up the system while we read the files for the displaying in the web interface, and unless we give the user the right access in the sudo config file in /etc/sudoers it wont work, this is on an FC4 system done thru the command visudo.
In short follow the instructions in the ReadMe.txt file section 7.
_________________
Best Regards
Tom Stage
Sat Dec 02, 2006 3:08 pm
Profile WWW
Post
Can you post your config file in /etc/sudoers? Also in ubuntu distro i have command visudo. :)
Thank's.
________
Kawasaki Zg1000
Mon Dec 04, 2006 6:05 pm
Profile
Post
Hi ziopippo
Mine looks like this.
Code:
apache ALL= (root) NOPASSWD: /bin/cp, /bin/chown, /bin/rm
_________________
Best Regards
Tom Stage
Mon Dec 04, 2006 8:44 pm
Profile WWW
Post
This is mine:
Code:
  GNU nano 1.3.12           File: /etc/sudoers.tmp
# Defaults
Defaults        !lecture,tty_tickets,!fqdn
# User privilege specification
root    ALL=(ALL) ALL
# Members of the admin group may gain root privileges
%admin ALL=(ALL) ALL
#Apache permissions
I have also try with this
Code:
#Apache permissions
apache ALL= (root) NOPASSWD: /bin/cp, /bin/chown, /bin/rm, /var/log/, /tmp/, /var/log/apache2/
but the error messages don't change. :?
________
FERRARI 348 SPECIFICATIONS
Tue Dec 05, 2006 10:02 am
Profile
Post
Hi ziopippo
Hmm now iam blank, i have no idea why it wont work on your system, but then again all my testing is done on a FC4 system, but then again i would not think that it would make a diffrence.
I need to think about this one.
_________________
Best Regards
Tom Stage
Tue Dec 05, 2006 10:39 am
Profile WWW
Post
Ok thank's a lot.
________
Vapir No2
Tue Dec 05, 2006 11:32 am
Profile
Post
Hi ziopippo
I have found the following on the net, and it would seem that ubuntu have a more strict policy with Sodu than FC4 have.
http://www.psychocats.net/ubuntu/sudo
From what i can see on this page only the users who are in the admin group may use the Sudo command, so in my eyes there are 2 ways u can solve the problem.
1. Have the web user be a member of the admin group (should only be done for testing purpose), so start out with this, and see if it solves your problem.
2. Make an entry where the webuser group may allso use the sudo command, on this isue i cannot offer any help other than what is listed on the web site i linked to.
_________________
Best Regards
Tom Stage
Tue Dec 05, 2006 12:43 pm
Profile WWW
Post
Ok thanks anyway :wink:
________
How To Roll A Joint
Tue Dec 05, 2006 4:11 pm
Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
