View unanswered posts | View active topics It is currently Tue May 21, 2013 2:28 pm
Reply to topic  [ 3 posts ]
Total n00b: How do I start it?
Author Message
Post Total n00b: How do I start it?
I know virtually nothing about Linux. I read about ZoneMinder and decided to give it a whirl.
I d/l the ZMLarch live and installed that fine. Nothing weird happened. It said there were 201 upgrades so I did those.
I see the ZM stuff is all out there when I snoop around on the hard drive.
How do I start it?
How do I add it to the applications list? Or create its own icon to run it?
Fri Sep 03, 2010 6:04 pm
Profile
Post Update
I've had time to do lots of reading. I found somewhere that I should type:
sudo zmpkg.pl start
to start it. When I do that, it asks for my password, which I give it.
Then I get:
Bareword "ZM_PATH_MAP" not allowed while "strict subs" in use at /usr/local/share/perl/5.10.0/ZoneMinder/Memory/Mapped.pm line 83.
Compilation failed in require at /usr/local/share/perl/5.10.0/ZoneMinder/Memory.pm line 120
Compilation failed in require at /usr/local/share/perl/5.10.0/ZoneMinder.pm line 37.
BEGIN failed --compilation aborted at /usr/local/share/perl/5.10.0/ZoneMinder.pm line 37.
Compilation failed in require at /usr/local/bin/zmpkg.pl line 45.
BEGIN failed--compilation aborted at /usr/local/bin/zmpkg.pl line 45.
Any hints?
[/b][/code]
Sat Sep 04, 2010 5:26 pm
Profile
Post
Open your browser...
Sun Sep 05, 2010 12:48 pm
Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
