Page 1 of 1
[ 2 posts ] |
| Author |
Message |
andrebarradas
 YawCam + Zoneminder
Hi guys,
I'm using yawcam to use my webcam in windows 7 with IP 191.168.1.3. In Virtual box i've installed Ubuntu 10.04 with Zoneminder.In Ubuntu when i put in URL 191.168.1.3:8081 i can see the stream of my webcam but when i put my configuration on Zoneminder it doesn't work,the IP keeps red and i dont know why.Can you help me solving this problem?
Here is my configuration in ZoneMinder
General: Source Type - Remote Function - Modect
Source:
Protocol - HTTP Remote Host Name - 192.168.1.3 Remote Host Port - 8081 Remote Host path - /out.jpg Capture Width - 640 Capture Height - 480
Thanks for who help
| Sun May 27, 2012 6:39 pm |
knnniggett
Joined: Thu Oct 18, 2007 2:55 pm Posts: 163 Location: Shiloh, IL
 Re: YawCam + Zoneminder
I'm not familiar with Yawcam.
However, the first thing I noticed is that the url that was entered into the web browser was "192.168.1.3:8081", but further down you've got the remote host path set to "/out.jpg". You didn't state where that came from, but that corresponds to a url of "192.168.1.3:8081/out.jpg" which is different than what was stated initially. Recommend you verify you've got the correct remote host path.
The url you want is the one that tells the yawcam to steam a raw video stream with no html borders, frames, buttons, etc. just raw video.
Another thing to verify is that the resolution entered into Zoneminder, 640x480, matches exactly what yawcam is sending.
Also, does Yawcam require authentication? If so, you'll have to enter that appropriately into Zoneminder as well.
| Wed May 30, 2012 3:10 pm |
Page 1 of 1
[ 2 posts ] |
Who is online |
Users browsing this forum: No registered users and 3 guests |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
