View unanswered posts | View active topics It is currently Wed Jun 19, 2013 11:09 am
Reply to topic  [ 4 posts ]
How to add a new monitor
Author Message
Post How to add a new monitor
i am completly new to zoneminder, and i think i got a lot of questions in the future. But for now, one big problem i don`t can fix myself.
I install zoneminder on ununtu 11.04 via apt-get install zoneminder. After all seem complete, i connect to localhost/zm and i see the Zoneminder Console.
Then i try to Add New Monitor. A new window appears, but i can`t click to any tab of it. So i can't set a source as example.
I hit "save" to try, the monitor appears in the listing, but even here, i can't edit or delete the monitor. The buttons don`t have any effekt.
Can somebody help whats going wrong?
I access zoneminder with firefox or opera browser from a ubuntu 12.04 system.
Tue Jul 24, 2012 7:51 pm
Profile
Post Re: How to add a new monitor
It may not help, but have you tried restarting ZM and see if the program was not working? Or the whole computer? If you installed ZM on a 11.04 computer and your running on a 12.04 can you access ZM from both computers through the ip address? You can access it from localhost/zm or <ip address>/zm. (example: 192.168.0.100/zm)
_________________
Aelingil: I need to waste my time, my clients time and another techs time, just to fix a problem with you server & filters?
Tech Joseph: Yes, you are correct.
Wed Jul 25, 2012 4:19 pm
Profile
I'm trying to figure this out too. I have the same behavior (I can't access the tabs in the monitor set up windows; I also can't use the edit and delete monitor buttons). I've done just a bit of googling, and it seems to be something related to a javacript problem. Something to do with mootools (whatever that is). I don't know whether the browser affects this. I've tried with Firefox, Chrome and Safari. I'm going to try it with Explorer when I have a chance. Any help would be appreciated.
EDIT: by the way, I've got version 1.24.something, installed on a headless plug computer using debian squeeze.
Wed Sep 05, 2012 7:07 pm
Profile
Found out what my problem was. Checked aptitude and although javascript-common was listed as a recommended install, it was not a prereq for Zoneminder or mootools. So I installed that, and now I can use the tabs. Still can't see video, but that's probably another problem. Thx.
Thu Sep 06, 2012 3:21 pm
Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
