View unanswered posts | View active topics It is currently Wed May 22, 2013 4:04 am
Reply to topic  [ 1 post ]
Problem downloading generated video
Author Message
Post Problem downloading generated video
I tried to search for this in the forums but couldn't refine the search enough to zero in on this issue. I just installed 1.24 on Ubuntu 11.10. I've had a number of ZM installs over the past few years. With this version, and I think I saw the same issue with 1.25, I could not download a video that I generated from an event. The file was usually 4kb in size and wouldn't play in VLC. After poking around with IE (I normally run google chrome) I noticed that the link to download the video was missing the events/ folder in the path. Everything else seems to work but downloading the video file. I edited the video.php file and added events/ to the line that creates the download link and it works fine now. Is this a bug or is this a miss-configuration on my part? like I said, I've installed this a number of times over the years and normally take default paths etc.
If this is an issue for other folks I can give more details about what I did to fix it.
Anyway, thanks for a great app. Rob.
Tue May 08, 2012 6:03 pm
Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
cron
Powered by phpBB® Forum Software © phpBB Group
