View unanswered posts | View active topics It is currently Fri May 24, 2013 9:39 pm
Reply to topic  [ 1 post ]
kill -HUP zma pids
Author Message
Post kill -HUP zma pids
In have an area, that I'm guarding with zm, but due to sun light changes it gives me a lot of false alarms.
So, I'm changing MinPixelThreshold field in Zones table during the time of the day.
I noticed that killing -HUP zma pids doesn't reload the new MinPixelThreshold settings from the db. Neither does with -TERM.
Restarting zm with zmpkg.pl does the trick, but this gives a small downtime (~ 10 seconds).
Looking in the src I can see, for example, that HUP signal triggers eventually ReloadZones() -> Zone::Load() which reloads all zone settings, but in my case I don't think that it does. Am I I correct or I'm missing something?
Btw, I have version 1.24.2 (ubuntu 11.04 package).
I've also tried a different approach, by using the zmdc.
First, I enabled the debug mode and then I restarted zma with zmdc. For example: zmdc.pl restart zma -m 4
Then, I checked the debug log for MnAT (I suppose this is the MinPixelThreshold value):
/tmp/zm_debug.log.16145:04/22/12 14:01:19.799402 zma_m4[16145].DB1-zm_zone.cpp/50 [Initialised zone 30/top_area - 1 - 215x231 - Rgb:ff0000, CM:3, MnAT:25, MxAT:0, MnAP:3746, MxAP:0, FB:3x3, MnFP:2809, MxFP:0, MnBS:2341, MxBS:0, MnB:1, MxB:0, OF: 0]
, but it doesn't change.
It changes only if I restart zma with zmdc 2-3 times.
My guess is that I'm missing something. So, the question is, what's the safest way to change MinPixelThreshold value from db directly and the have it applied in zma processes?
Thank you
ilias
Sun Apr 22, 2012 12:24 pm
Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
