View unanswered posts | View active topics It is currently Fri May 24, 2013 12:21 pm
Reply to topic  [ 11 posts ]
h264 rtsp source from bosch ip camera
Author Message
Post h264 rtsp source from bosch ip camera
Hi, hope this is the right place to post this type of question.
I have a bosch ip camera, that can do mjpeg, but i only get ~1 fps that way, it also does h264 streaming.
The stream works well, i can see the video if i connect to it with vlc
Code:
vlc rtsp://192.168.1.60:554/video.mp4
But how do i connect it to zm?
Things i have tried, unsuccessfully:
type: remote
protocol: rtsp
host: 192.168.1.60
port:554
host path: /video.mp4
type: ffmpeg
source path: rtsp://192.168.1.60:554/video.mp4
Any ideas how to get this working?
Thu Oct 13, 2011 7:42 am
Profile
Post Re: h264 rtsp source from bosch ip camera
Try leaving only this in the source path:
source path: /video.mp4
Hope it helps,
PacoLM
_________________
miniITX system + 4 IPCams + 1 Webcam (ZM1.25)
Thu Oct 13, 2011 9:38 am
Profile
did you mean that using ffmpeg as source?
Thu Oct 13, 2011 9:50 am
Profile
Just try it, I do not know if you could set the ffmpeg as source. Do you have access to the snapshots of the camera using another path?
PacoLM
_________________
Thu Oct 13, 2011 11:46 am
Profile
well if I understood you correctly, then i have tried that and it did not work.
Thu Oct 13, 2011 2:52 pm
Profile
Could you give more data, for instance, an extract of the /var/log/syslog file when trying to connect to the camera.
_________________
Thu Oct 13, 2011 3:05 pm
Profile
i was looking at /var/log/zm/zmdc.log and missed the syslog, this really seems important, here is the log:
Code:
Oct 14 10:11:10 zoneminder-riga zmc_m13[15991]: WAR [Can't find payload details for video payload type 35, name H264]
Oct 14 10:11:10 zoneminder-riga zmc_m13[15991]: FAT [Unable to get RTP Info identifier from response 'RTSP/1.0 200 OK^M CSeq: 3^M Session: 578b03e66876358^M ^M ']
Oct 14 10:11:10 zoneminder-riga zmdc[2732]: ERR ['zmc -m 13' exited abnormally, exit status 6]
ps. if i change the "Remote Method" from "RTP/RTSP" to "RTP/RTSP/HTTP" then this is the error i get:
Code:
Oct 14 10:14:40 zoneminder-riga zmc_m13[16077]: FAT [No RTSP sources]
Oct 14 10:14:40 zoneminder-riga zmdc[2732]: ERR ['zmc -m 13' exited abnormally, exit status 6]
Fri Oct 14, 2011 8:12 am
Profile
so, no ideas?
Tue Oct 18, 2011 7:08 am
Profile
If it makes you feel any better I'm having what I think is a very similar problem with my Launch IP camera :)
viewtopic.php?f=21&t=18263
dan
Tue Nov 01, 2011 9:31 am
Profile
dan
no, doesn't feel much better :(
Thu Nov 03, 2011 3:11 pm
Profile
Did you have any luck sorting this problem?
Tue Feb 21, 2012 3:41 pm
Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
