View unanswered posts | View active topics It is currently Tue May 21, 2013 8:42 pm
Reply to topic  [ 5 posts ]
Uncomplete german translation?
Author Message
Post Uncomplete german translation?
High!
in ZM 1.24.2 it seems to me that a lot of translations are missing. Especially explaining texts are displayed in english only in the optins dialog.
- are these texts translateable?
- if yes: is there a howto what to download for translation and howto produce the translated version?
If so: I'll do my best to complete the german translation to the newest version and send you back the files.
Regards
Nukem36
Thu Jun 17, 2010 10:26 am
Profile
Post Re: Uncomplete german translation?
old thread but I will warm it up :wink:
Nukem36 is right, there are a lot the non translated strings in 1.24.2. This release is still in Debian Squeeze so many of german Squeeze user will see this. Can someone answer the question from Nukem36?
I don't know if he is still reading here, so if there is some posibility I would also translate the missed strings.
Sun Jul 31, 2011 9:14 pm
Profile
Pm Zoneminder with your ability
Mon Aug 01, 2011 12:27 am
Profile
O.K. I started to translate the missed strings. It works for the "normal" entrys.
But I had a problem with the array for the translation in the options menu.
I used the given example.
Code:
//    'LANG_DEFAULT' => array(
//        'Prompt'  => "This is a new prompt for this option"
//        'Help'    => "This is some new help for this option which will be displayed in the popup window when the ? is clicked"
My first edit did'nt work.
Code:
$OLANG = array(
             'Prompt' => "Standardsprache im Webinterface",
             'Help' => "ZoneMinder erlaubt im Webinterface das Benutzen einer anderen Sprache wenn die Datei fuer die gewuenschte Sprache vorhanden ist. Diese Option erlaubt das Umstellen der Standardsprache welche mit dem Paket ausgeliefert wurde \(British English\) zu einer anderen Sprache.",
So if I change the locales the related entry in the options menu is empty. It seems that the array is accepted but the values are not used. Because I'm no PHP specialist I'm not able to make a little debuging output. Can someone help here.
Btw: If I take the given example there is also no text visible, so I don't think there is a problem with the translated text itself. The also available file for romanian with translations did'nt work.
Thu Aug 04, 2011 7:35 pm
Profile
Code:
Code:
$OLANG = array(
Solved: http://www.zoneminder.com/forums/viewtopic.php?p=78704#p78704
Wed Jan 09, 2013 1:32 pm
Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
