View unanswered posts | View active topics It is currently Fri May 24, 2013 1:54 am
Reply to topic  [ 13 posts ]
how to activate/deactivate alarm when I leave/enter my home
Author Message
Post how to activate/deactivate alarm when I leave/enter my home
I am new here and dont know where it would be right to place my question. I am also new to zoneminder and want to know if my project can be realized with zoneminder and what other hardware would be necessary.
I want to observe my entrace door from inside my home. When leaving the house I want to activate the alarm function in zoneminder and an email is being send to me when something moves. Coming home again I have to deactivate the alarm again. Lets say I need 3min to leave the house. I activate the alarm and the camera with motion detection can see that I am leaving, which doesnt trigger an alarm email. When coming home I need 2minutes to deactivate (however) the alarm function. If this is not happening I will get an email.
So who do I get this working? Is it possible? What hardware do I need? How to trigger the alarm? The best would be a small panel working with wifi wlan 2,4ghz where I can enter a code and which is saying : 2minutes 30secounds until alarm is ready! Maybe an app for android or iphone would work to.
All I got until now is a small debian home server without zoneminder running.
I am excited for you replies.
regards
thomas
Mon Oct 31, 2011 7:02 pm
Profile
Post Re: how to activate alarm
Have you created a filter to send the email?. ZM automatically does not send an email on alarm, the system should be configured.
_________________
miniITX system + 4 IPCams + 1 Webcam (ZM1.25)
Mon Oct 31, 2011 7:25 pm
Profile
I know sending mail s is possible with zoneminder, that is not the question here.
The question is how to activate the system/alarm with a 3min timer and which hardware to use for it? Should be very easy my mom could use it! Or what else could be possible.
I dont have any hardware (except server) until now and am still planing what to buy.
EDIT: In zoneminders script section I found a "wake" option to wake up cameras. This could wake/sleep a camera (timer could be included in script). Maybe I write an app for ipod to start that script. Dont know how until now and hope someone did this before.
Mon Oct 31, 2011 7:44 pm
Profile
Post Re: how to activate/deactivate alarm when I leave/enter my h
Can anybody tell me if the project can be realized or not? Did anybody something like this?
Sun Nov 06, 2011 3:12 am
Profile
You might try some x10 capabilities like the key fobs to activate a monitor remotely.
Sun Nov 06, 2011 6:22 am
Profile
Thanks for your reply. I read about X10 capabilities but didnt get the point. I am totally new to this. I would need some hardware atached to my server to control this? Dont I?
Would like to buy AXIS M1054 with alarm input/output find it here http://www.axis.com/products/cam_m1054/index.htm.
You know more about this or where to find?
Fri Nov 11, 2011 12:10 pm
Profile
You'd need to buy some additional hardware to enable the X10 features. My system has been running for several years now, and consists of the computer running Zoneminder connected through a serial port to an X10 interface called a CM11A, which can send/receive x10 signals over house wiring. I also have an X10 wireless transceiver that can talk with x10 wireless devices like the key fobs and relay the signals over house wiring to the x10 computer interface. So when a button is pressed on a key fob, it sends a signal to the wireless trasceiver, over the house wiring to the x10 interface, and through to Zoneminder which can be configured to activate or de-activate a monitor. You would be able to simply press a button on the keychain remote when you leave to activate a monitor for a camera to begin recording or watching for motion, and deactivate it the same way when you return. Naturally, there's a lot more you can do with this x10 stuff, but this addresses your immediate request.
The web site for x10 stuff is http://www.x10.com where you can find the transceiver for $12.99. Keychain remotes are $19.99 for a pair. The CM11A is no longer sold through x10.com, but is available at http://www.thex10shop.com/roduct/x10-ge ... -interface for $39.99.
As far as the M1054 is concerned, Zoneminder works with most network cameras as far as I know. Mine are all hard-wired, so I can't speak directly to this.
Sat Nov 12, 2011 2:55 am
Profile
Thank you I will look into it. Sounds pretty good!
Sat Nov 12, 2011 12:06 pm
Profile
Maybe this other method come too late but there is maybe another way to do this with dropbox :)
look here (sorry it's a french URL):
http:
//blog.guiguiabloc.
fr/index.php/2012/01/06/dropbox-allume-vos-lumieres/
To resume Guiguiabloc open light in his garage with a small file paste in dropbox space.
With "INCRON" (apt-get install incron - sort of cron based on inotify lib) Guigui's server check change in dropbox mount drive and if a particular file is create or remove (for example a file call startalarm.txt or stopalarme.txt) a custom script start or stop.
It's maybe possible to use zmpkg.pl with incron too :)
with zmpkg.pl you can start/stop/restart zoneminder. You can also create custom script to set your monitor status (monitoring/modec/morec etc ...).
Fri Jan 27, 2012 2:45 pm
Profile
I have been thinking about knocking something up to test whether my smartphone is connected to the house's wifi to enable/disable emailing alerts.
Fri May 04, 2012 9:50 pm
Profile
Yes - a script on the server that periodically tests for the presence of your phone's IP on the lan and then controls zm using zmpkg.pl or zmtrigger.pl should work provided you never turn your phone off.
Sat May 05, 2012 6:57 am
Profile
I have made a script that logs into my router and detects if my android or gf's iphone is connected to the wifi. Unfortunately it seems our devices aren't permanently connected to wifi when they're on for some reason.
Oh well, back to the drawing board!
Sat May 05, 2012 10:06 pm
Profile
Just a FYI. I'm currently working on a Windows .Net project that will interface ZM with a HAI Omni Pro II security controller. http://www.homeauto.com/products/haisystems/omnipro2/omnipro2_tech.asp HAI provides a .Net SDK for application development for its line of security controllers. I will be using that SDK to create my interface.
Currently, I'm at the point where I have the equivalent of James Wilson's Windows Live Viewer. I still have to implement the interface to the HAI security controller. My ultimate goal is to monitor all the exterior Passive Infra Red (PIR) motion detectors for activity via the security panel. If any of the PIR's are tripped, my app which is constantly monitoring the security panel will change the function of the camera in the PIR area from Monitor to Record and keep it in record mode until the PIR resets as indicated by the security panel
The HAI panel has both Android and iPhone apps available.
Mon May 07, 2012 5:24 am
Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
cron
Powered by phpBB® Forum Software © phpBB Group
