View unanswered posts | View active topics It is currently Fri May 24, 2013 10:24 pm
Reply to topic  [ 1 post ]
Alternative to mjpeg-streamer for use with bt878 & 2 cam
Author Message
Post Alternative to mjpeg-streamer for use with bt878 & 2 cam
I have a remote linux box with a BT878 card and 2 cameras. I'd like to present these as IP cameras using something like mjpeg-streamer but mjpeg-streamer can't handle multiple channels for the same video device (e.g. /dev/video0 with a camera on channel 1 and another on channel 2).
Does anyone have a suggestion of an alternate application that can handle this ?
I could probably do this using 'motion' and disable the detection, but it seems a bit of a heavy-weight solution.
Mon Jul 13, 2009 12:41 pm
Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
