The Wanscam FR4020A2 Pan/Tilt camera is a Foscam clone very similar to this camera Foscam FI8918W Pan/Tilt Camera. As a clone it should work with the generic control script found here Foscam Clones, but it doesn't. It is similar but it is not compatible. Left and right pan is mixed up. IR light on and off is mixed up.
Hello , Thanks for buying our wanscam IP Camera. Would you please let us know the web UI version and the firmware version of your camera,then we can send the the firmware for updating the camera. Best regards Jerry
Fri Jul 13, 2012 3:25 am
branderco
Re: Wanscam FR4020A2
Hello Jerry
Nice to see that you found my control script. If you follow the link in my first post you will find web UI and firmware versions.
PT camera firmware: 0.37.2.43 web UI: 1.0.0.0
Outdoor camera firmware: 0.35.2.47 web UI: 1.0.0.0
There is nothing really wrong with the cameras. They are just a little bit different. If you change the firmware and the web ui I will have to change the control script too....
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
